need urgent help !!
Guest eokh
Folks
something on my W124 is freaking me out
i was wiping the interior of the rear windscreen (back one)
the rear passenger door was open and the rear interior reading lights were turned on.
after i finished my task... closed the door .... the lights doesn't go off
i don't recall there being a switch to turn off the lights in the rear ... or is there really one ?
can some kind souls point me the correct way ?
don't want to end up with a flat batt tmrw morning
thanks cheers.
  • Replies 6
pls ignore my post !!
problem solved... i was meddeling with some switches earlier bcos the rear headrest will not fold downwards
accidentally left the rear lights switch on... without even knowing that was the switch
sorry for inconv caused !!
Haha...false alarm. Glad it was solved. :D
actually not really problem solved
yes, i managed to find the root cause of the rear cabin light turn on.
now ... i found out that my rear seat headrest cannot fold down by pressing the button !!
anyway small problem to me lah. forget it.... lufff it off lor
my old w202 had that problem... lucky the newer models got a button on the headrest to manually over right.
Guest qes78
brudder.
Try using the switch only when ur engine is running. Switch doesnt work otherwise
