My C280 Dyno
Guest MB C280
Guest morganoh
Hi Bro,
Your stock HP seems very high...258? Thought the original specs is rated at 231 for a V6 3 litre...Maybe I am seeing wrongly.. :)
I did my dyno at ThiamSeng too.
They remove the Rims and connect the it directly to the dyno machine.
Was told it was more acurate, cos no need to factor in the HP lost on the Tires.
But its still not very Acurate cos theres still HP lost in the Gear Box Transmission.
So they roughly estimate theres a 20-30% HP lost and calculate backwards
If the Dyno at the wheels is around 200HP. by considering a 20% HP lost in the Gear Box,
so the Estimated HP will be 200 + 40 = 240 HP.
If guess , we will never know the real figures, not unless we remote the engine and dyno directly on the Engine,
Guest MB C280
overall the drive is good i think what i am happy about is the torque 60 Nm is very fun to drive when you need to do sudden pick up or over taking the power bent is wide best if you use the paddle shift to downshift to 3 rd gear
in singapore drive throw away the BHp torque is what you need
anyway iam happy what my saleman have recommed. $65 for 1Nm
did not dyno the original data
original by factory 231Hp 300Nm
they give the paper after they done .
they siad they did 2 run
gain is 35hp 58Nm
Original factory specs of 231Hp 300Nm is at wheels or flywheel?
Your dyno charts description reads power & torque @ flywheel & not wheels!
