i cannot take it anymoreeee !!!
Guest eokh
Folks
as i hv posted previously ... my brake pads were worn and high time due for a change.
due to my recent purchase causing a big dent on my wallet.... i had been procrastinating this job as much as i can bcos i believe the pads will still hold up for another month of use anyway.
unfortunately ... little Mrs Better Half had been nagging and nagging me to go get it fixed ... til i hv attained my boiling point.
OK ... so now i have to get it fixed.
Where would you go to get the job done ?? Any recommendations will be heartfelt appreciated !!
Pls PM me if not convenient to mention wkshop names openly
thank you 100million times !!
cheerios !!
  • Replies 11
Guest clarkewan
if u want cheap and good...
and if u r near pandan loop area...
u can go to the workshop behind my factory...
they are quite good and cheap....
:D :D :D
normal and general servicing i look for them...
as for pads, u can try surpass which i always get from them....
67476016
hi Clarke ... me not in jurong side.
me in toa payoh side.... but thanks very much for the tip !!
hi 9339 ... do you think MBM will "give face" even if I don't hv the SG Merc decal ?
i believe change brake pads is a relatively simple job ... most workshop shd be able to do it ... just $$$ I suppose ..
besides $$ .... the damn car has to be able to stop !
i was at another wkshop for my old car.... the car was unable to stop after that !!!
bcos there was a air bubble in the piping !!
Can try Dennis of Nam Sing at AMK Autopoint.
HP 96200365
Tell him Dr Benny sends you. ;)
But seriously, the shop is very competent and my TE is fully taken care there from the smallest to the big jobs. :thumbsup:
HP 96200365
Thank you sir !!
Guest nismo502
HP 96200365
I go to Nam Sing to get my car done too. I must say that they have served me whether if it is servicing to R&D modification. You should also talk to Ges for advice.
Folks
thanks again for your kind advise
i might need to just leave the car there bcos i hv other biz to attend to.
Not free to stand there and supervise.
i presume this wkshop reliable enough to "Do as they say, Say as they Do" ??
Folks
Goes to MBM, join them as member with a low fee,forgotten how much but sure is below $100 a year, they will pick up your car for servicing / repair @ no extra charge and return to you once done....save that thru and flow time to make more money......
