W124 - Starting issues
Guest qes78
Guest qes78
Man,
Over the past week, the W124 has died on me twice.
First time round, i towed the car, replaced with a new Maintenance free Battery (S$180) and new Starter (Valeo-S$330).
Drove for a week before........
Towing it (out of a Multi Story Car Park), changing the starter (borsch-S$200)
I hope that's the end of it....towing is expensive.....and a waste of good time.
  • Replies 10
Guest alumetal
Happens to my on my w124 previous.
My prob was the fuel pump..... cannot start at all.
Trick is to use an umbrella and knock at the bottom.... wake-up the pump.
Yeap ... also check the igination coil too.
Guest qes78
keep us update.
car seems to be ok.
Duno why the rear passenger foot wells were soaked though. When I collected the car, the seats and carpets at the vertical portions all dry, but the foot weels were soaked underneath the floor mats. Carpet was entirely soaked
Guest qes78
go check your spare tyre well and its side well. If there is H2O.. Then you are going to have headache reaching for the leak! :surrender:
No water there
Phew!
Guest alfman
This happen to once when i drove a w124, There are drain holes with stopper underneath the carpet and rubber foam . The stopper might have came loose so all the water on the road when raining g came in from the drain hole.I hope it helps
Guest qes78
I'm hoping to hell that it was just a water bottle that leaked. Will update when I can.
Hardly drive the 124, only on weekends. My daily mode of commode uses much less gas...
