Help!!
Ramesh
You see it there... means its from them... otherwise its not there.... unless the dealer really go that extra mile to cheat you of that extra 2k.... which is unlikely...
On 12/18/2016 at 5:57 PM, Ramesh said:
Hi All. I just paid deposit for a E250 Avangard model. It is a July 2013 model. The C&C badge is behind the car.
How can I confirm that it is a C&C car and not a PI car.
Thanks a lot in advance.
You can check the VRN & or VIN with CnC.
If the car is imported by CnC, they will also have the service records which they might not be revealed to you.
When you buy a CnC used car, you can registered yourself as the new owner of the used car with CnC
