Cars done up by Dynotechnica
30th April 2018. Mercedes Benz CLA200 doing Dimsport map update and service GFB dv+.
We did the turbo actuator renewal as well as the muffler seal ring to solve the boost leak issue.
Attached is the reviews by James after solving his boost leak issues. Thanks James.
22nd May 2018. Mercedes Benz GLA200 doing B+ svs package and engine mounts change.
Full Maintenance (ASSYST Plus Service B+)
Every 4 years / 60,000 km, whichever comes first.
Lubricants and Parts Replacement
1. 5W50 EO
2. Engine oil filter, air / dust filter, fuel filter#, auto transmission filter
3. Transmission fluid
4. Coolant
5. Spark plugs*
Check and Top-up
1. Fluid level of windshield washer, power steering, brake, transmission and rear window washer system#,
2. Tyre / spare tyre pressure
3. Radiator coolant level, water ratio
Electrics
1. ASSYST system reset
5. Battery load test
6. Alternator performance test
Tyres and Rims
1. Tyres condition checks, rotate and balance tyres
2. Alloy rims and rim bolts condition checks (only upon wheel rotation)
Engine
1. Engine compartment wash
2. Engine V-belt check
3. Major components leakage checks
4. Check chafing, routing of lines and damaged components
5. Exhaust system checks
Brakes
2. Brake efficiency check
Others
5. Front suspension joints, track rod, drag link joints condition checks
7. Door and lid catches, gearbox mounting, propeller shaft companion plates condition checks.
1st June 2018. Mercedes Benz upgrade hardware is in the house! MACH5 Turbo muffler delete is in! Turbo flow better. Sound a bit louder, faster spool, better boost with  more responsive shifting. Overall a good hardware not to be miss! After installation car will be more zippy on the road with enhanced drivability.
Very reasonable pricing :) call us for details at 96919222. Suitable for Mercedes Benz CLA, GLA, E class w212 and A class.
