Very Foul smell from aircon! Like salted fish.
Guest SgLaKsa
Guest SgLaKsa
I noticed that the foul smell always comes out only for the first minute that the aircon is turn on. After a minute or two, it won't be there anymore. (I always press the button to prevent outside air from entering the car). I've tried not to press that button so as to let outside air enter, but instead of solving the problem, the foul smell was blown out more frequently during the drive in this case.
Does any expert here knows what is happening and what i should do?
Thanks.
Guest SgLaKsa
This is normal for all cars I think, it's probably the stale air trapped inside your aircon when you start it.
But the smell is getting from bad to worse, smelling like salted fish or dead rat now :tazzie:
SgLaKsa ]
Honestly, i think its REALLY a dead rat lor!!!
Guest SgLaKsa
narmi ]
kekekekeke... :) but thinking again, maybe thats true hor :surrender:
Try driving your car for at least 30min with the window down,air con on but temp set to the higher(mean heater), the smell should gone after that.
Is should be due to mist and wet carpet/floor mat .
just press the demister button can liao.
u mean using heat to kill germs?
Guest SgLaKsa
Ok will try that out bros, thanks for suggesting
Guest SgLaKsa
A friend of mine once had a lizard die in his aircon and it smelled TERRIBLE until he got a mechanic to disassemble the entire thing to take a look and fished the rotting lizard out.
Its quite possible lei..
my friend got a kitten stuck before until die!
he didnt eat meat for a whole week lor!
Seems like must strip down the system in order to find out :surrender:
Thanks.
Are you driving a W211? If so, I had a similar smell before and sent it to Cycle to fix a few times until they changed my condenser and never had the same problem again. I believe it had something to do with the design of the condenser trapping water for tropical weather. I can't remember exactly the explanation, but it is a design problem that can be fixed.
Guest tategoi
Try blasting at the aircon at the highest fan speed every morning when you first start your car, and in the evening when you are about to reach home, for 5 mins. It worked for me in my previous ride. After a week the smell was gone.
Guest SgLaKsa
GASTON ]
I noticed that the foul smell always comes out only for the first minute that the aircon is turn on. After a minute or two, it won' wrote:
Hi GASTON,
Mine is R171 so dunno whether the design is the same as W211 or not, anyway, it sounds like a good possibility. Thanks, i will get workshop to check on that :thumbsup:
Guest SgLaKsa
Hi tategoi,
Did you do that with hot or cold temperature? 9339 suggested using hot temperature. Thanks man :thumbsup:
Guest SgLaKsa
Could it be the air con filter that need to be replaced? I had that also in my GTI, but after changing the filter, now no more smell liao...
Hi exile, thanks for sharing your experience :thumbsup: I'll check the air filter too :punk1:
Guest SgLaKsa
I've tried blasting the fan at highest speed and temperature for 25mins of drive, Phew it was dam hot man. My wife really couldn't take the heat and kept complaining whether it's necessary. We were like in a sauna even with the top down :surrender: But it really worked, although not totally yet, maybe has to go for another round of sauna drive :surrender: At least the foul smell is 80% reduced now. Thanks to 9339 and Tategoi
Guest tategoi
Haha, but turning on the heater will definitely kill the smell faster. In my case, I kept the temperature at 22 and blasted till the smell was gone everytime I started my car. After one week the damped smell had disappeared.
Sorry my bad as i forget to tell you, "do it alone at night".. :iconsalut:
