W204 Wheel/Tyre Upsize and Offset
Guest LeeCH
Hello everyone. Gong Xi Fatt Cai greetings. Some questions regarding the above mentioned topic.
1. What is the maximum offset that W204 can take?
2. AMG sports package comes with a standard 225/45/17 at the front and 245/40/17 at the rear. Was thinking if upgrading to the AMG C63 18" (Front 235/40/18 Rear 255/35/18) or 19" (Front 235/35/19 Rear 255/35/19) rims, will it rub the fenders. Got some info on the net which says the rim size for 18" is 18X8 ET 45 (F) and 18X9 ET 54 ®. 19" Multispoke is 19X8 ET 45 (F) and 19X9 ET 54 ®. I take it as the ET 45 and ET 54 as the offsets of the rims mentioned.
Many thanks to all the gurus' here for your answers. Cheers and Yam Seng!!
  • Replies 15
Guest tategoi
I have the 18" 5-twin-spoke AMG on my W204, no rubbing at all. If the rims are original, I don't see any problem fitting them onto any C-Class. You mean the 19" multis-poke are available as a factory option? Damn!!!
Guest kopimonster
yes...those are the offsets....and its also important to get ur PCD correct when changing rims....else nothing works...if you are intending to get those AMG rims from C&C, best is to seek their advise first....And IF you are intending to install bigger brake calipers, you might want to take them into consideration as well.
Guest kopimonster
CBlack ]
i' wrote:
bro, your setup is power :thumbsup: i lurve staggard setup, performance aside, it always give ur car a more aggressive stance
And I am on staggered: 235/30/20 (front) 255/30/20 (rear)
A bit regret should have gone for 265 on the rear..... :'(
bro, your 20" will sure be awesome looking, but does it affect your ride comfort? juz checking, you are driving a w204 hor? if so, i am really suprise the w204 really have such high tolerance, my previous B7 A4 platform can only take up to 19" max, if i am not wrong.
i also a bit regret leh, should have gone for 20" instead :tongue1:
kopimonster bro, long time no see u leh, do come to the next meet up. dying to hear the roar of the C63 again :pray:
Regret ??? Let me help you Jason........
I help you to use your 19" on mine, you go change 20"... Hahaaa
then i have to start all over gain and wait for months :tongue1:
This time round, you have me waiting with you......
