W212 2010 side mirror dim
Junda15
  • Replies 4
Hi can I check does both the side mirror of W212 2010 dim when vehicle behind is on hi beam ? Or it is the right side will dim only ? Thanks alot
Right side only.
To confirm: u simply look at the side mirror of both left and right, u should notice the side that dims, the mirror has a "border dotted line".
Cents
Right side only.
Cents
Thank u. It's only the right side that dims.
I have another question is when I go into reverse gear. My left side mirror tilt down, when I move off my car in d gear. The left side mirror do not tilt back to the original position. Any settings on this ?
It does tilt back but not immediately when u shift to D... it shift back in abt 3sec.
If it still does not shift back, try pressing your left side mirror button (leave it lited) on driver's door, then set it into memory (M1, 2, 3), still leave it lited, it should be fine after.
