Error fault appear
AY8686
  • Replies 9
Hi anyone knows whether when the left signal/ high beam isn't working due to weak battery? Mine came up this morning, when I signal left the front light doesn't have the signal light and when I high beam, it isn't working too
What is your ride? Have you modified the headlights before?
It could also be the fuse issue , do check the fuse
