Lighting and Run Flat Indicator display??
Guest NCS
1) In the steering on-board computer lighting setting manual,
for the headlight mode, there is "constant" and "manual". I read the user manual but still catch no balls about the meaning of the "constant" mode.
Can anyone advise? What the advantage of "constant"? Shall I set to "constant" or "manual" as I use auto headlight most of the time...
2) In the steering on-board computer display, when push the arrow "up" button...
a menu shows
"Run Flat Indicator active
Menu: R-Button"
What does it mean?? What is R-Button? How does this function works?
  • Replies 3
1) If I am not wrong, constant is for the light to be always on in Auto mode. This is for countries like Austria where the headlights need to be always on regardless. Well u can always test it out during the day time.
2) This is menu where u need the reset the RFI, press the odo reset button to reset it. It is lighted up when it detects one of your tyres pressure is low which a slow puncture or faulty air stem valve.
Guest camelot
a menu shows
Menu: R-Button"
For 1)
It means the angle of your headlight. If you set to constant, it will always be angle to a fix distance. If you set to manual, you will see a scroll switch next to your headlight switch, you can manually adjust the height.
For 2)
The R-Button means the Reset Button on the left side your of your dashboard.
Hope that helps
