How to fit K&N drop in filter into C180 - W204??
Guest NewC180
Guest NewC180
Hi Guys/Gals,
I've just bought a new K&N drop in filter for my C180-W204.
Happily open the bonnet to change it, and discover that I couldn't find where the air filter is!
Anyone knows where is the air filter and how to change it yourself? Lazy to go to the workshop...
Thanks!
This lesson teaches you that.....
You are not a qualified to open the bonnet.....leave it to the workshop , they need a living and they have family to support :devil:
Do come by this month end GTG, I put it in for you......Need to arouse her.....lub liao than easy to put it in la...
I bought 2 filters this morning, one for my 523 an the other for my c180. Popped in the 523 in less than a minute, but having problems with the c.....
like what 9339 said, come down this meetup, we insert 4 u
Guest morganoh
stand in front of the car facing the bonnet, open the bonnet.
theres a air intake hole on the left of the front bumper
this air intake will turn right around 40-60cm (towards 3o'clock direction) and then turn left (towards 12o'clock direction) for another 10cm before it reach a rectangular box.
There's a few screw u need to remove on the box cover, and your filter is underneath the cover.
Hope it helps
U will need the Throx screwdriver... btw anyone got any butt feel improvement, improve reving from the drop in ?
I felt zilch after popping in mine. do like never do lor.... haha...
Lucky it is a free gift from Performance products.... haha long story...
Guest NewC180
I bought the filters from a company in Genting Lane, and they are supposed to be the distributor for K&N. However, they do not provide installation. I guess I'll just go down to a workshop and get it done.
BTW, the filter is a cone shape type and not flat type, is it correct? Because the one I've got for my bmw is a flat one.
Thanks.
Guest NewC180
Hope it helps
Just changed the K&N filter at the workshop this morning. Apparently, the location of the air filter in the C200 and C180 is different. In the C180, the air filter sits somewhere on the right of the engine. You need some special allen key to open up the cover to change the filter, and the filter is cylindrical in shape. K&N P/N is E-2011. Just some info for all who are keen on this.
Guest morganoh
Hi Morganoh..
I read in the past that u used Hurricane..where and how much can I get it for...
I am not keen on KNN oil based....
Thank u....
i can really feel the diff immediately after I install the stainless steel mesh filter.
The engine rpm rev up more easily, especially around 3500-4000rpm and above.
my initial motive for installing the stainless steel filter is to save money
cos I read from one of the members that C&C charges $70 for a filter and another $20-50 for replacing the filter.
my stainless steel filter is $150, so it more worth it before I start my 1st servicing with C&C
NewC180 ]
Hi, mind to share where to buy at Genting lane? Add & Co name?
Guest NewC180
mmkm ]
Speedworks Pte Ltd: 85 Genting Lane #03-04 Guan Hua Warehouse Bldg Tel: 67437288
Hi morganoh ..
Thank u..but just curious why did u choose Hurricane over KNN?
Just in case..I am not trying to start a debate here... :punk1:
Hurricane no oil(lesser chance to fault MAF) and it is BLOODY easy to clean
KNN, altho brand is better, is oil base and u have to use cleaner to clean and reoil which is very precise cos too little, u will get bad filtration, too much and u get ready to buy a new MAF
just my 2cents
just my 2cents
But if U do it well, the filtration will be better right? :clap:
Guest morganoh
just my 2cents
but can u or the workshop guy really do a go job in oiling the knn filter?
do u want to risk damaging the MAF which may cost thousand of dollars (sorry I dont know whats the actual price)
The risk is definitely lower if u used a Stainless Steel filter.
But no Risk if u use the paper filter.
Even though the stainless steel filter does not work as well as knn and paper,
it does not concern me as I change my oil every 5000km as compare to most who did theirs every 10000km.
