Tyre pressure indicator
Guest dewey
i rem its something like switch on power with ignition (don't start engine), then press reset button.
but i think i missed something in between... have been trying for 2 days still cannot....
is it the runflat indicator notice? and reset? cause thats the only one i know, cause i reset twice this 2 weeks already. the press 3 times in ignition will only get service indicators, dyno mode and some numbers. and battery voltage i think.
Guest kompressor9938
Hi. The handbook says : 1) make sure the key is in position 2 in the ignition lock.
2) press the menu control to go to "Run flat indicator active"
3) Menu : R-button +
4) Press the reset button on the left of the instrument cluster
The following message appears : Restart Run Flat Indicator?
Yes Cancel
Press the + button to confirm restart.
The following message will then read : Run Flat Indicator restarted.
Good Luck. Happy exploring.
Yes Cancel
tks for help, i will try later.
was ur car silver f/l 211? saw at commonwealth on sat afternoon.
Yes dewey, that's his car which i told you.....he actually went out and wanted to look at your E63 but you left.
Bro dewey, your car :thumbsup: nice...... :-*
Sorry i cant help as my W204 are diff from W211, my reset are so much easier.
Walau, i must compliment you guys for the efficient flow of information!! Better buy a car bra and disguise my ride when i am not out with my wife....
Anyway, was really eager to look at ur car with the amg kit. Been thinking if i should fix up the amg or the lorinser kit... Hope to see you at the meetup?
Goodday...
i had not been showing up for meetups for a very long time as i'm always outstation.
now in HK, wont be back until Dec...
as for the kit, i think u'll never regret with AMG...
Arigato Gozaimashita!! Thanks for ur advice. Look forward to meeting with you.
Take care. :thumbsup:
