W124 16valves Model - Need comment on Engine Performance
Guest MB98
Noticed the car abit dragging when engine is hot (Say after travelling above 30km). Noticed the drag especially going up a sloppy road.
The problem disappear upon engine oil change(1st 500km to 1000km) next you can feel the drag coming slowly. Worse around 8000km after Syn oil change. Is this normal for 16 Valves model. Experience any mod to overcome this ?.
Thanks
  • Replies 14
hi GP,could it be urs is a 8 valve n mine is a 16 valve? could that have affected de FC?also i tend to drive is harder..now trying to reduce pressure on de pedal..
16V should give better FC!! Our cars are tanks! Play with half depress when speed reaches 60 to 70, rpm around 2k and above, that's when you will enjoy the real power! And this also will give better FC!
