Malfunction Sign light up
Benz8899
  • Replies 5
It can be anything, just pop your car to your usual workshop to get it checked
  • 3 months later...
I got my problem solved by just replacing a small valve/seal from the air reservoir tank.
It could also mean a few things:
1. Weak air compressor
2. Leaky valve block
3. Leaky airmatic pipes/hoses
"Malfunction" refers to air in the system takes longer than usual to fill up. So it usually corresponds to the leaks somewhere.
hope it helps.
I have a spare air compressor(airmatic) if you need drop me a PM
hope it helps.
Hi can you help me on the same issue as i am having the same problem with my car  - 2009 S300L
