How to reset the "Check Tyre Pressure" notification?
Pam177L
The "Check Tyre Pressure" kept appearing on my Speedometer and notify me to check pressure and reset after checking.
I had physically look through the 4 tyres and they look ok. May I ask how do I go about resetting the notification?
I had tried looking through the user manual but can't find the page advicing on the resetting procedure. Appreciate any advice rendered. Thanks.
If yours menu function are same as mine my model.. (W204,2007).. Can try go to service (using the left right arrow on steeling wheel) Then u see tyre pressure .. Select it .. U will see restart with ok .. Just press ok in steering wheel .. It will reset the indicator. But of course do check the tyre physically ensure all is properly inflated before u do this step.
Hope this helps
Thanks Level Z,
I forgot to indicate that mine is a W211. And I suppose the menu function are different and I dont have "ok" on my steering.
Will wait for Bros on W211 to further advice.  Thanks.
U are welcome mate ...
shouldnt we top up monthly? - mine on nitrogen
I would say check daily before you drive is best .. if the tyres need top up very often, then there may be a problem which should be look into by a tyre shop. just saying... :)
