How to do up speedo meter
Guest MB98
Anyone upgraded their W124 speedo meter with chrome rings ?
Do I need to remove just the plastic cover (Direct from front) or I need to strip the whole speedo meter set & do it from behind.
Thks
  • Replies 13
Hi Mike,
Any lobang where can do. (Hope my mechanic can help).
I intend to spray it jet black & put on the chrome ring. Change the speedo light to LED (Maybe file the light gap wider-so more light can shine into speedo meter cluster).
Hi bro,
Thanks for the valuable tips. I finally managed to remove the whole speedometer cluster this morning, clean it, modify the rings a bit & completed the mod.
NICE ! !
But ..... What next ?
  • 3 months later...
Guest starnite
Hi bro,
NICE ! !
yo bro, i also thinking of taking it out.. care to share experience?
Also, show how does ur dial look now, with the chrome rims?
Need to remove the whole instrument cluster, unplug the 4 connectors to the various meter/switch etc
From Rear - remove all 3 meters, clean it , Mount the metal rings in a reverse mode (If you used plastic chrome rings -You need to trim it slightly ) I do add on some s.s decorative parts to make the meter look more interesting.
