Improving steering feel...
Guest redhood
Redhood and Noitalogesto, u both drive the same car...
how come 2 different types of steering feel? i've driven both the slk200 and slk280, but not the 350 yet, i found their steering to be acceptable - not as rock heavy as the w203 c class and not as light as the w220 s class...
maybe u both should meet up and test each others ride?
:offtopic: redhood... i give u heavier steering... swap ur slk with my c class... "LEAVE THE PROBLEM, CHANGE THE CAR..." :yumyum: :yumyum: :yumyum: :offtopic:
unless u opt for the direct steering™, it will feel light at slow speed and heavy at high speed OR Redhood got bigger biceps then me...
btw the cheapest way for a heavy go-kart feel is to drain ur power steering empty. which i dun recommand
Guest redhood
u wannt try mine?
i adjust my front camber and toe to tracking purpose...
now u have to fight it...
Mine's stock and I don't think got Direct Steer, so maybe that's why the steering feels "indirect". :-\ running on stock 17"s with CSC3s.
It just occured to me cos' I recently drove a beemer and felt that the steering feel is so much heavier with better accuracy, and mine is a sportier car. :banghead: maybe it's the run flat tyres...
will definitely take up your offer, deh! when and where?
Guest redhood
no thanks. Thought I left the problem when i sold my W201.
u wannt try mine?
do u know that there is no free lunch in the world?
ur front tyre will wear out more then usual(actually mine still seems new after 5kKM+ 1 tracking session)
toe-out("what i feel") will make the steering abit harder & any uneven surface on the roads will have a jerk on the steering...
lets say a normal sg road, i release my hand and the steering wheel seems to be dancing according to the road surface,
any dips or cracks make u go: "What the hell?!? SLK r u trying to tell me the road tax we are paying is not worth the road condition?"
Guest redhood
Noitalogesto ]
u wannt try mine?
aiyah, some of the roads in Singapore really leaves much to be desired, even on the plush stock settings on my ride. I don't blame the F1 drivers for saying our track is bumpy. It's bumpy even on a normal car!!!
but coming back to steering feel, would wider wheels make enuff difference? Are you running 18s or 19s?
redhood ]
u wannt try mine?
im running 19" 235 in front which i dun recommand, 225 is the optimum
redhood ]
u wannt try mine?
u try driving on the road opp Rail Mall...
what the hell r they thinking??? trying to break my suspension so i must replace a new 1 and give them 7% profit?
redhood ]
u wannt try mine?
Redhood, did u opt for the sport suspension?
Guest redhood
Noitalogesto ]
redhood ]
u wannt try mine?
aiyah, some of the roads in Singapore really leaves much to be desired, even on the plush stock settings on my ride. I don' wrote:
don't think I have sport suspension. It's very soft, so cannot be. Must ask C&C the next time I bring it in. I am happy with it 90% of the time, since humps and bumps don't transfer too much to my ass.
redhood ]
Noitalogesto ]
u wannt try mine?
i feel the stock suspension is kinda semihard for everyday driving tho... but it too much bodyroll for tracking...
i heard that the brabus lowering spring will 1)Lower ur ride 2)make SLK less twitchy at hard cornering 3)lesser bodyroll, while maintaining the stock feeling
direct steer does it help to make the steering wheel feel lighter ?
mine was quite heavy i prefer light feel as light as audi
any idea if i install direct steer it will feel light ?
please advise
er, i dun think u can, it fixed from germany...
i think it the whole rack and pinon...
btw, how come u say ur one too heavy for u and u want a lighter steering???
Redhood, how come u say ur one too light and u want a heavier steering?
Guest redhood
Will the Brabus make me slower at humps? I feel the travel of the stock springs are really scary sometimes. In fact, I've hit the bottom of my chassis once over a hump at Commonwealth car mart. Really ridiculous. Thus, I'm worried that if I lower the car, I will kena jialat jialat at every hump.
actually the stock springs i go VERY slow on humps cos i realise that even at normal "roadster" hump speed, u will scrap a little bit on the front bumber which u will never notice even u bend down to see but when the car is hoise UP u will see it...
but i think lowering of the stock ride height of SLK is ok in SG since many people also opt for Sport Suspension and some Singaporean owns a SLK 55 which is even lower!
just go slooooow on hump... heck any1 who high beam or horn u for going that slow... after the hump let them smell smoke for being impolite :iconsalut:
oh ... cant be help.
mine's the latest facelift slk what about redhood ? Are u having the same ride ?
A qn: whenever i corner i could feel the boat effect from my rear its so unstable
anyone encounter this ? All stock ?
Does changing the ARB and Suspension helps ?
Anyone can recommend a very reliable workshop that can check on my wheels.
recently after changing to a 18inch rims, when ever i corner to the right i got some grinding sound from my rear tires and when i am doing a reverse there is few grinding sound...
i ask the shop before installing it they say no problem wont have sound .. sickening
pls advise
pls advise
whats ur stock rim size?
can u attach a pic of ur car on the side profile so i can see the clearance and get a better picture.
(u may also PM me)
btw, if u UP size ur RIM u have to readjust ur suspension alignment because the ride height is different.
isit a tic tic tic sound or a "rubber rubbing against body" sound?
caractae_slk ]
mine' wrote:
boat effect[/b] from my rear its so unstable
how fast are u cornering???
its sound like there are not enuff downforce on the rear...
Guest redhood
Yah, I agree that Direct Steer is not an after-market option. Must order from factory, otherwise, too bad.
Mine's an '06 pre-FL 350. I don't think there is Direct Steer. My steering is very light, almost can drive with just thumb and forefinger. Dunno why Caractae's is heavy. Maybe our definition of heavy and light quite different. For sure, my biceps is only size of "little mouse", so can't say I too strong for my SLK. Too sexy maybe... haha! :punk1:
Guest redhood
I have the same feelings on the steering as well. may i know anyway to improve it please? thanks
Can try the cars above n see what the have done n compare.
Actually, in recent months, I have come to enjoy the soft handling of the SLK. While it does not give u razor sharp feedback, when driven hard, it does feel sure-footed. At the same time, I appreciate the soft ride on our less than perfect roads.
