Some tweak to ur W124 for better response..
Guest Mike
For 16 valves owner:
1. Replace ur current rating 5 trimmer plug on ur PMS module with rating 1.( timing advanced )
2. Flip out ur throttle cable for softer Acc pedal feel.
3. Adjust tranny cable till first gear start.
For 8 valves owner:
1. Remove ur R16 resistor to advance timing.
2. Check if ur EZL dial is at Setting No. 1 for advanced timing.( applies to onli model with the adjustable EZL)
3. Flip out ur throttle cable for softer Acc pedal feel.
Guest ericlim1338
Bro, nobody seems interested.
16Valve - I replaced mine yesterday, perfect feel... :la:
Worth a try, cost very little only...
Anyway thanks Mike for recommending and buying that tweak for me. Cheers
Wah, you really dig into the mysteries of W124... :thumbsup:
How much is the cost of all those recommended fixes?
And does it affect the fuel consumption?
What do you guys mean by 'first gear start'? I think the car starts at 1st gear in S mode anyway, right? or wrong? :P
nv dig it has been done to my car long time ago and i have to take the trouble to other the small little part from US... and now i found it in singapore so just share with the owners here... fuel consumption is not afftected... unless u start to heavy foot. =) u must slap the acc on S mode den first gear start... after adjusting the transmission cable even in E mode with light foot u still have got 1st gear start but ur shift point will be a bit higher .
Guest alumetal
sorry ah, me novice and had got a 16V w124.
can explain more on the below ?
1. Replace ur current rating 5 trimmer plug on ur PMS module with rating 1.( timing advanced ) - How to see and where to buy ?
2. Flip out ur throttle cable for softer Acc pedal feel. - can explain how to do this ?
3. Adjust tranny cable till first gear start.- can explain how to do this ?
  • 5 weeks later...
