Airmatic warning lamp come and goes ?
Auto-Technica SC
I am keen to know any bros and sisters out there had the problem I face...
1. Air matic logo malfunction pop up on screen any time of the day
2. Try to raise the four suspension - it goes up normally - but the pump make abit of noise
3. leave the four susp. raise up overnight- next day same - no sinking
4. start engine next day the error message went off by it self
5. each time the error pop up - the message will disappear without havinf to plug into the
    diagnostic scanner to erase DTC
6. drive as per normal - all four susp. same level.
7. but did notice the air pump do make quite abit of noise each time it level itself -
8. 2013 july C & C replace the air matic valves - cost me 1k plus
    and the noise is there since then - just recently the message pop up.
9. adviser Jack did mention the air pump not in good shape- just use it first.
  • Replies 4
Replace the pump......
should cost around 1k ......If do outside...downtime 20-50mins
alamak  happy too early- the light come back. even new pump orginal. when I rise up it still make the pumping mechanical noise
it is normal.
same problem, the light will goes off when u off the engine and restart after a while. hazzzi
Maybe it's airmatic suspension leak.... Maybe u bring it for another check?
