Door unlocking problem!!! Help!!!
Hey Bros, I encountered a problem with my w204. I am on keyless so when I open the drivers door it will only unlock the drivers door while the other 3 door remain lock. Then if I open the any other 3 doors first all 4 doors will unlock. So any bros could share on how to solve this issue ??
  • Replies 6
There is an option you can select from your dash display thru your steering wheel menu. If I did not remember wrongly, it has been set to open driver door 1st than all passengers door for security reasons.
using remote
- press unlock once will unlock driver side only
- press unlock twice will unlock all
This is an option, can choose to unlock all by pressing once only.
Using keyless, i think all 4 doors will be unlock (default)
Go check your owner manual.
There's something written about setting your keyless to unlock driver side or all your 4 doors.
