Run flat tires
Unimog
Yes. But b200 for chrome they give KNS type. For sports then give continental. For b180 worse
wa lau, mine is B180. I think need to change. I heard CSC 5 is good. Goodyear AS2 also not bad.. Are they run flat tyres?
Bro use it for 1-2 year then change, save money!! if you going to change rims then trade in for high price!! U can tell them new tyre~
im thinking of changing to 17 inch BBS CF. so maybe will trade in. usually how much can they fetch?
Run flat, wear out faster, i do not know why as well.
It make ur car feel more jumpy .....
Run flat tyres are generally heavier and of stiffer side walls, hard as rock hence jumpy. Some brands manufacturer makes "special" suspensions to couple w run flat rubber to give a more comfort drive. Price of run flat mostly cost more compared to conventional or even performance tyres. Great impact on FC!
Disadvantages outweigh benefits of non-flat. In Singapore context, just simply fit up a TPMS to monitor pressure, get remedy before it goes totally flat. Kiasu? standby wormie patch from autobacs/Stamford tyres shall simply do the job.
Does w246 comes with TPMS? It has tyre pressure indication though. Can bros advise?
TPMS do not come with any car as off now. W246 and most other conti cars YOM 2012 and later has a run flat indicator which detect if one tyre is leaking air faster than the rest and require topping up of air.
It does not detect if all 4 tyre are leaking at a constant rate.
TPMS u could get it at most petrol station or tyre shop or even car hardware shop, just tell them tyre pressure monitor.
