engine stop by itself
Guest daxchin
Guest daxchin
need some advice,
i experience this with my c200, w204
anyone knows why the engine will shut off by itself when doing a quick reverse parking..
isit a safety feature in the c200?
auto car where will stall one...
:iconsalut:
  • Replies 6
Guest daxchin
yes bro... i kena this a few times... when I engage the reverse gear, then quickly stir my steering wheel, then reverse into my parking lor at slightly faster pace.. (as i was rushing for time) the car "emergency stop" all indicator lights flash on... had to pull out key then insert and start engine again.. damm.. is this normal ??
thot it only happens to manual cars....
kindly advice bro... :iconsalut:
My previous B170 had almost a similar problem but engine stopped when moving out of parking lot!
After C&C changed the fuel tank, fuel tank seal, crankshaft position sensor and going in and out of the workshop, the problem still persist!
You moved from D to R too fast ?
In the MB experience, when the car rolled back after a spin too much the engine is cut to protect the gearbox. It even auto move to neutral.
Pls flip through the manual or the interactive manual... pretty sure it is one of those safety feature..
need some advice,
:iconsalut:
bro my advise for you is avoid quick switching of gear, quick steer your steering wheel to max. damage either of this will cost you a leg, arm maybe neck.
Or unless you have bigger project in mind........
C63 AMG ? :clap:
