Licence Plate Light W204
Guest slimy
  • Replies 4
Thks for the advice. Was thinking of doing it myself as seems easy and paiseh to bring down to them....
For what i know...W204,once a small bulb change, error message will appear, need to fix in some resisitor or something like that,now just bulb.
that is true. you need to remove your truck cover and splice two wires connecting the bulb. After which, the resistor will bind the two wires carefully without ever touching them. Just a note, you need to get the resistor or else an error message will appear.
