Help, white spot on wheel caps
neost
water with cloth.... I had something like this near my wheels before it is a kind of mud.....
Try use some car wax to polish it off!
It is not mud.
Tried with wax. Cannot remove too
Probably corroded by brake fluid - go change it then!
If really corroded by brake fluid, then I probably has a bigger problem on hand. I am OK with the white spot and has no intention to do anything. But leak brake fluid better don't play play. What other signs to look out for? I will observe for a couple more days or weeks before deciding what to do next
Cement ? Hard for us to tell without feeling it.... Not confirm if it's brake fluid also...
Actually you are not the only one has that, I have seen many Mercedes with this wheel cap design has these delimination. Try go to the drive in tyre shop in Pandan Loop, you can see some wheel cap taken out are all like that.
Looks a bit macham like kenna STD hoh.
