Help, white spot on wheel caps
neost
water with cloth.... I had something like this near my wheels before it is a kind of mud.....
Try use some car wax to polish it off!
It is not mud.
Tried with wax. Cannot remove too
Probably corroded by brake fluid - go change it then!
If really corroded by brake fluid, then I probably has a bigger problem on hand. I am OK with the white spot and has no intention to do anything. But leak brake fluid better don't play play. What other signs to look out for? I will observe for a couple more days or weeks before deciding what to do next
Cement ? Hard for us to tell without feeling it.... Not confirm if it's brake fluid also...
Looks a bit macham like kenna STD hoh.
