Tyre Pressure
Currently driving a W204 and on 17" rims. :batman:..
Just want to ask the recommended tyre pressure as the gas flap doesn't seem to indicate recommended pressure for 17" :iconsalut:...
C & C recommended 210. But I've been using 230-240.
Guest jenvid
I believe not. Always refer to manufacturer specs.
But the rule of +2PSI for every rim size +1, & hot air compensation +3PSI seems to be the norm.
My E93 needs 39PSI at the rear & 35PSI at the front.
Guest jenvid
May I ask why the difference in PSI for front and rear?
rear higher as need to support the weight of all the gold bars he keeps in his boot :D
Haha... How i wish.
Diff ? Beats me. It is printed on the car. Got a shock when i saw the numbers. But apparently it is norm. Heard some folks do 40+
Best thing is u incre front pressure to increase oversteer.
I suspect it gotta be due to the 50/50 balance...
Guest Berlok
Haha, btw today I tried to pump my tyres to about 35 PSI for start.
But I kept getting an error on the machine, this happened to all 4 wheels...
Lowered it to 33 PSI and it gave the same problem... Anyone knows why?
Guest jenvid
haiya... never RTFM... :la:
Ur TPM needs to be reset once u inflate tyre.
Also rear needs to be a bit higher than the front cuz merc tend to understeer.
Can explain why having a higher tire pressure on the rear wheels helps on the understeer problem?
