Burning Plastic/Rubber Smell in car.
mulderang
Please refer to this....
Left is blown, right is not.
I might suspect something worst that might happen. example cable issue best is to go back to workshop or CnC.
I recommand spark @ comfortdelgo as well.
http://mbworld.org/forums/c-class-w204/465331-tail-light-connector-melted.html
Found the source the of the problem i think, i have the same issue just thay my wire are not so "cooked" yet. This is the reason why on saturday morning the smell did not return. Rear lights not on...... my warranty is out, any chance c&c might do a good will repair for me? Any bros had the same problem before?
highlight this to your workshop they would be able to assist you
For me, dragging it will produce those smell.
On a side note, is it a must to press the "air ciculation" button to prevent air from outside to come in?
The button dissappers and need to re-press it like every 30mins, is there any way to permenantly have it set?
Is this the same for all models?
mine have the same prob when i drag. C180k
any idea what it is? cnc says nothing wrong!
so I'm not the only one...I have that feeling that somewhere somehow it came from the exhaust be coz it smells just like it! Leakage?
  • 4 months later...
Front pole light u mean?
