W221 - Recurring problem: Noise when driving for 30 minutes
s7000
Hi, I am driving a 08 W221.
I have this problem. After driving for around 30 minutes, the car will make some "clunking" noise when going over small bump or turning.
I had the mechanics went through the all the metal and iron stuffs at the front and back. After fixing it, the problem is back after 2 to 3 months.
I went through this 3 rounds for the last 10 months.
Anyone have similar problem? or know which mechanic to fix this for good?
This is a PI car, cannot go back to C&C.
Thanks
  • Replies 21
Try Round Motor. The boss is ex CnC Tech. will be able to assist you
Yes
Hi S7000,
Did you manage to solve your problem? I seem to suffer the same problem but not sure it's after 30 minutes of driving. Some 'plastic clunking' sound when going over raise surface, turning and barking too. However, the mechanic did not find any fault both time I send my car in for other matters. I am just ignoring the noise at the moment.
Regards
Thanks
I still have the clunking sound problem. But don't understand why the problem start only after around 30 minutes of driving.
The last mechanic i tried was Yu Yi at Dunearn Road. The problem was fixed but back again 2 months later.
I am still looking for recommendation to fix it permanently.
Hi S7000,
Do you have any problem after applying brakes? I notice sometime the sound do come after I brake. Lately, the sound seems to fade away (or I did not pay attention) after I did my servicing 2 weeks ago and I ask them to roatate the tyres. I will take note if the sound still comes back. Btw, I use Chip Soon located at Tampines St 93. Maybe you can give them a try. Both Daniel and Jason are very nice guy.
What we had been talking is purely guessing as we may not be talking about the same thing. You definitely need a good 'doctor' to solve your problem.
Anyway, for my case, I think the problem still persist but had lessen as I heard the noise again this evening while on my way home. I am not going to treat it at the moment unless I feel that it had worsen.
Hope you can resolve yours soon.
Btw, just for sharing. My previous W220 had ignition problem as it dies after refilling. The mechanic was not able to find the fault until I voice my opinion that this problem seems to be fuel pump related as it is identical to my first encounter when the fuel pump was faulty. They then replace the fuel filter again and during inspection, they found oil around the filter which should not be the case. I was being advice not to pump too full during each refill. After that the car performs without any further fault.
I do understand from the guy that bought my drive this fault did come back again. Maybe he did not heed my advice of not pumping to the max. Anyway, it is a really tedious and lengthy exercise for detecting the exact fault for me. As we are driving the car everyday and they merely base on our feedback and trial and error, it will not be easy to pinpoint every fault we complain. Sometime, we just have to live with it.
Update on my recurring noise problem.
Managed to solve the problem.
Took bro Takashi Kazumi advise. Went to Round Motor. After some checking, they were confident that the problem was due to the front lower arms.
Although they were quite new but they are not original parts. The mechanic insisted to use original parts for the lower arms.
Changed to original parts, and problem solved.
As the mechanic said, S-Class is quite sensitive, certain parts must be original as the quality of the non originals are not good enough. And lower arm is one of them.
Credit to Round motor.
haha thats good. The guy who work on your car should be Kuan.
Only this guys service S-Class the rest works on E and C class.
Thanks for the info.
During refilling, do you all notice that we can top up large amount (around 10L) after the pump automatically cut off.
I like to fill to the brim to have maximum mileage per petrol tank (if not to the brim, unable to get range of 900-1000km).
Maybe i should avoid doing this to prevent damaging the fuel filter, thanks again.
I cant get more than 700km per tank on my W220
Yes, my previous 2006 221 also can get at least 600km per full tank.
My current 2012 model slightly better, abt 700 to 800 (if lots of city driving/heavy acceleration).
Pls note that my is base model 300 only, heard the S350 CGI model gives better mileage.
With highway, its 900 plus to 1K.
My record is 1300km, mainly leisure cruise control along NS highway, only 2 persons on board with minimum luggage.
Tyres - stick to stock 255/45 18.
Also i prefer to hyperinflate 42-44 psi (when cold).
and try to service at C&C always with their original parts, safer in my opinion.
Lastly, quite often, i off the climate control, prefer the panoramic roof fully open (unless highway speed).
I am using mainly shell 98 but still cant get more than 650km per tank when drive in Singapore.
When drive to KL it is slightly better, around 800+km / tank and not more than that.
For 1,300 / tank, how can I achieve that?
For tyre pressure, you have 42psi, what is the standard recommended for your car?
i think I will try to hyper-inflate mine to 42 too.
Cruising at 110km/hr is effortless, such that drowsines set in hehe.
Did not capture the 1300km record achieved recently.
Remember that our tank can filled up to 90L, need to top up manually after auto cut off.
From full to 3/4 tank, can travel at least 200km, sometimes 300km, enough "savings" to cross over to JB to fill up.
