Hot la dey!
Guest quacks
Guest quacks
Is it just me... or is the weather getting hotter nowadays?
My air-con seems to be failing... sometimes it will blow hot air... sometimes it will be normal... but never really cold (if you get what i mean).
Any recommendation for workshop to check (and service/replace if needed) air-con?
PS: Car just came back from C&C service so i think they should have topped up the air-con gas right?
  • Replies 12
Guest quacks
I dont think they will check the air con was it cold, only when you requested than they will "CHANGE IT".
Alamak.... thanks for the heads up.
Now my air-con is so much cooler. :D
MBM? does MBM do air con as well? or try MarkKool
Not sure leh, I was hoping one of the bros here have experience with those specialist air-con shops....
Can I have more info on this MarkKool? Thanks! :)
went to Markkool on my previous few jap cars, a guy, think his name is ah huat, is very very good at diagnosing air con problems. i wud recommend going there to get air con fixed.
