one key instead of two
Guest jameslhm
  • Replies 3
for my car i need to keys one for the door one for the starter.... any one have the same issue?????
bro,
i believe you are trying to say, you got 2 keys? 1 for the door, the other for starter?
you can go to any locksmith change the set of keys to 1, meaning - they would have to replace the starter key hole and the door key hole too..
i had changed mine due to the engine starter key started to jam whenever i off engine and tried to pull out the key..
I think is not change, they can adjust the bearing to make it BOTH HOLE WITH 1 KEY......
Another easier method, invest in a remote alarm, than you wont need the key to open that door.
