Tire & Rims Sizes
Guest Prado
Guest Prado
Hello , can anyone advise for tires sizes ...
Front tires @ 225 / 40 / 18 , so what is the correct size my rear tires is supposed to be ?????
thanks in advance
  • Replies 8
Guest Prado
btw make sure ur rear rims spec is for 255 size tyre
Actually got a rims upgrade from SE , but what he is telling now is size is at Front 225 / 40 / 18 - 7.5 J , Rear 245 / 40 / 18 - 8.5 J ..
If 8.5 J , dun think can fix 255 , so need to be 9 J ????
Any experts can help ???
Guest Otsego
8.5" can fit 255
Stock Tire - 255/35R18
Section Width: 10.03 in 255 mm
Rim Diameter: 18 in 457.2 mm
Rim Width Range: 8.5 - 10 in
Overall Diameter: 635.50 mm
Sidewall Height: 89.154 mm
Radius: 317.75 mm
Circumference: 1996.4 mm
Revs per Mile: 831.3
Guest Otsego
oh can u tell me what car is it for btw?
for SLK200 i think 245 is enuff for FC and traction... with the 350 Power u will need more grip
i dunno what MB is thinking with the skinny stock tyre... even my mom drive will lost traction... :censored:
Guest Otsego
Its for SLK280 .. SE is trying to tell me that its 245 max , not 255 ... Think need to talk to him again liao
Thanks alot Noitalogesto ;)
oh get 255 for a V6 engine ;)
Guest Otsego
the reason SE tell u that 245 is the max is because they want to follow the specs given to them.(Paper with numbers)
in actual fact...http://www.1010tires.com/TireSizeCalculator.asp it can be done :)
i remember asking my SE about changing my rim to the AMG 55 but he also say cannot la, better keep stock for "safety reason" :yawn:
they only dun want to do troublesome things.
Also how come both profile is 40F 40R?
our SLK is noseheavy so we need more front profile 40(to support the weight -I believe-) and lesser rear 35 to make it balance.
if u could look at the side profile of the whole car, it quite slanted where the front is lower then rear
