The Super Engine Oil Thread!!!
Guest fruitcakepablohoney
Ok, found this engine oil comparision, you'll be very surprise!!!
Test was carried out using the Falex Lubricity Tester,similar to the Timken OK Load Rating Test.
Shell Helix did badly!
Mobil1 did badly too..At least the cheaper Mobil Synth outperforms their flagship model Mobil 1.
Castrol Formula R also did badly..
2nd most ex...Red Line didn't do well either..
Most ex, but best in test...Royal Purple (synthetic oil) Racing 51
Royal Purple...
  • Replies 32
alamak bro. got headache reading halfway. wats the bottom line???
Bottom line is...avoid Shell Helix, Mobil1, Castrol formula R!!! :(
Guest jenvid
aiyo.. royal purple has been renowned for its superior quality in the boy racer circles for a while. But the darn oil is &*^*(^^%$#% expensive lah....
My merc 1 year run 46k leh... always use royal purple hor.. car deprec increase by 10% liao lah..
I rather let it wear man.....
Silly you...
Guest sy69u
so avoid all those brands.
now, which is the best?
The brand "Knife", second to best and lot more cheaper.
fork & spoon also not bad lor
Guest Cklasse
People...it's a Mercedes-Benz la....use knife brand ! can at least use a bit expensive one la....something like EXTRA Virgin Olive oil.
Guest morganoh
I bought Royal Purple , 1 box of 10 bottles, 10W50 fully syn.
at $12 per bottle, (each bottle is 1 quart = 0.9+ Litres)
So 3.6 Litre is $36.
1 bottle of mobile one is around $70+ (4litre)
So isnt Royal Purple much more cheaper?
Guest jenvid
hmm... price must have dropped significantly... The last time I came close to the oil was almost 8yrs back... keke...
Police wear shorts time lor... hahaha... No no I also not boy racer hor.. wahahaha
10W50 errr got 0W40 & 0W30 or not ? I stock up liao... ;D ;D
Guest sy69u
if the royal purple is tat cheap, we can group buy to get it cheaper. hahahahahahahaha. i so cheapskate tats y can drive merc. hehehehehehehe.
i start.
1. sy69u
Guest morganoh
i start.
1. sy69u
No need group buy , cant bargin also,
cos Price is already very very cheap only $135 fpr box of 12 bottles, (per bottle is 1 Quart)
self collect
just call these mervyn from vantivetech.
91073464
Just call them currently they have
5w-20 5w-30 10w-30 10w-40 15w-40 20w-50
and
5w (Slightly more ex at $ per box)
Fully Synthetic Characteristics ,
5W, 10W, 15W, smaller = able to use at lower envronment temp.
The last 2 digit represent thickness of oil.
20,30,40, 50 smaller = thinner,more nosiy engine
bigger = thicker = engine silent
So Jenvid not need to buy 0W40 & 0W30, cos 0W are for those freezing weather. for spore wealther, it makes no diff using 0w 5w 10w or even 15w.
What u want is if u are casual drive go for a thinner oil like 5w-20.
If u want to go tracking or also rev your engine go for 10w-40 15w-40 20w-50
(the last 2 digit represents the thickness of the oil)
Guest jenvid
and
Hey thks !!!! Switch from 30 to 40 oil & my avg oil temp increase by 10 degC. It is now hovering at 110 while previously it sits bet 95 to 100.
Guest Titan
I am tempted... can specify the oil I want or bring my own when servicing at C&C?
No we can't, we have to use their Shell Helix as long as you service with C&C.
You can for sure.......
Only wty void mah....
Guys, don't anyhow order hor...only either one of these 'model' is good!
Royal Purple...
Guest sy69u
think u can bring ur own oil but the service charges will still stay the same regardless u use theirs or yours.
Guest hwong
Now my ride mileage coming 3k... will check with SE when booking for 10k servicing. If can use will try make plans to go for RP 10W40... Thanks everyone for your input.
Guest ultor
Near my office there is this shop that is stocked up with purple bottle engine oil, I think it must be royal purple, going to check it out after reading this review. Before this, I thought it was auntie selling some cheap oil.
Has anyone tried it yet?
