noisy steering, right side
fishcake42
I've been encountering a noisy steering on my b170 and based on audible feedback it's coming from the right side of the car, ie right of the driver. Anyone have any idea if its a defective steering rack that needs to be replaced and if so, how much would it set my back?
Thanks
  • Replies 5
Perhaps you can describe more detail like the description of the noise like tiak tiak, tock tock or orrh orrh...
i have all these sounds from my B170 before... go find a reliable workshop to work on it
If steering problem can be repaired... replacing will cost much more
oh it sounds like clog clog.... strangely it comes from the right side...
would you have an estimate of repair versus replace?
cheers
sounds like drive shaft problem which is quite common problems with car
expect 350 to 500 range for repair & i has never replace a drive shaft before so cant say much on replacement charges
There is 1 shop in sin ming area specialized is transmission repair & you can drive down to ask to verify if its this problem & quote before you commit to repair.
