7G Tronics
Hi Guys,
I'm newbie to Merc. Can I check something, just collected the car 2 days ago. Got it from PI car. Just to check regards to the 7G Speed. I assumed that there's 7 gears basically.
Mine has the E and S mode. There's a manual shift as well. My question is, I tried the manual shift, does it goes like this?
Each shift up will change the numeric up.
D - D1 - D2 - D3 - D4 - D5 - D6 - D (Back to D)
I checked in the youtube for a C180 CGI, it shows all the speed in a row 1 2 3 4 5 6 7 instead and shifting up will have a box boxing over the gear number.
Is this suppose to be correct?
Thanks
u try liao then u let mi knw... if nt maybe u can ask sg merc conduct lesson on gear changing.. lastly u can go ask ur SA if u still have doubts...
Its 7 speed... But manually cannot shift to 7th? D is obviously auto.
Ok ok.... Then u take it as there isn't a gear 7, go back cnc make noise... I believe they will have the ans to all ur questions...
If D is 7th then how you differentiate between the "7th gear D" and the "auto D"?
