Engine Check light
Guest jenvid
If u have no aftermkt mod, chances are there is a crack in your air intake manifold. Apparently this is quite common in the M271 engine block.
The job will take half a day to fix if it is really the case.
My W203 engine check like is on. Anyone here have the same encounter? What could be wrong?
Happened to my ride a few weeks back.
Water got into my Kleemann K-Box.
Rewired back to stock, everything seems OK now.
Guest Winningeleven
Happen to me few days back, the problem is i use those 3M fuel system cleaner ,after a few days the check engine light came on , i bring it down to my regular workshop they reset the system and everything seems fine now.
Really tks for all the feedback but seem like the problem can be big or small. I guess really have to go workshop to find out the real reason.
