Repair for Scratched Rim
Guest Berlok
Guest Berlok
Alamak!!! Scratched my rims today on the kerb... Quite badly I think, about 2-3cm deep at the edge of the rims and about 5cm long...
Anyway to repair the rim?
Guest morganoh
The way rim shops repair your rim is by cuting the edge of your rim inwards.
If your scratch is 2-3 cm deep. theres nothing they can do.
cos its just way too deep and your tire would not be able to hold onto the rims
Even if its just 1 cm deep, after your rims is repaired, the wheel balancing will be off. so can only use as a rear rim.
Guest Berlok
What do you mean by can only use as a rear rim? It is the rear rim that is scratched by the way.
