Electrical power from ignition
Guest Cklasse
Guest Cklasse
Anyone knows of shops that can do power extention from W203 ignition point?
I want to tap the electrical power from my W203 ignition so that I can charge my GPS whenever I start the car.
  • Replies 5
Guest Cklasse
Garmin Nuvi 370, ordered online from exepansys.com at S$960 including shipping.
Comes with TTS, US and Europe map. I use Malsing map for Singapore and Malaysia.
Can u use the electricity from the cigarette socket?
Guest Cklasse
My concern for using the ignition for power is it may screw up the engine start process.
I have tried the cigarette lighter socket (using the provided plug) but I want to hide the wire and keep the lighter socket free for my iPod. I noticed the power to the lighter socket cuts off when the engine is off, this is good for me so that I can leave the GPS in the car. If running the wire hidden in the panel is easy, I don't mind getting the power from the lighter socket.
ok, any shop capable of doing such things like running wires under Merc panels, tapping power?
I am always very concern with shops that take car panels apart from gut feel and not knowing fully the sequence or tricks.
Guest jenvid
Most ICE shops shld be able to do it. U can try Pin Liang at Zion Rd.
If you are more adventurous, you can DIY. The fuse to the cigarette I think is located at the driver side. Alternatively, you can tap the IU's power source. This wld run nicely together if u intend to put the Nuvi holder near the IU.
If you are using solar film, you will also need to get a external booster antenna.
Stick it at the black area on top of the rear view mirror or run it to the bonnet's wiper nozzle tray.
