Overheat sign popped up!!!
Guest SgLaKsa
Guest SgLaKsa
Anyone ever had the above problem? It happened to my car on Sunday (my car is 7 months old), overheat sign popped up while i was driving. I checked the coolant temperature and it was at the normal operating temp of 90deg, so i continued to drive home anyway. When i reached home, i checked again and found that the temperature reached 110deg. Found out that it was the coolant fan which failed to turn on when it should. Sent to MBM but they can't understand whats the problem with the computer and had to send it to Cycle :( :( :(
