Help Fuel Gauge
Guest nemo
  • Replies 11
Guest Cklasse
The B-class is an evolution of the A-class and is somehow related.....the W168 is its distant great grandfather.
The W168 had this particular problem of a fuel sensor failure after certain mileage and it was pretty common then.
My ex-W168 (A160) had a fuel sensor failed at about 100 000 km.
Fuel sensor is in the fuel tank.
Guest Cklasse
My previous A-class W168 decided to go into protection mode and locked the gear to 2nd below 10000km mileage.
The electronic component of the gearbox failed.
I am not surprise that there is a premature failure of component. It happened to my W203 when it was new.
Guest SgLaKsa
Yap, hope your SLK wont give you any pre mature problem :rockon:
Sigh! I'm the unlucky one lor, 17k km only got problem liao >:( Only 7 mths Young :punk1:
My fuel gauge not working . Pump petrol in full tank but fuel gauge still indicate Empty fuel. Anyone have this prob?? Pls advise?
Yup fuel sensor/float possible faulty or one of its wiring to the gauge loose? Anyway the needle doesn't even move up?
bro, i realised your car many problem hor? i read many of your post here and there you complaining about your car.
Komp, pls do some good deed, maybe his car lack of buka....
Guest nemo
Yeah they change my fuel gauge sensor liao!! Its the sensor prob hope from now on drive smooth smooth.... Thanks for all the Bro and Sis for your replies and help!! :afro:
