w204FL side mirror lights aka puddle lights
Jayson
Recently i figured out how to replace ugly orange halogen puddle lights to white ones.so hope this info helps.
1: remove the mirror and wires connected to the mirror.
2: remove the 2 bottom black screw with an allen key.
3: use a chisel type small screw driver to pry open the cache on the bottom black cover where the bulb it.
4: pull out the bulb and replace it with desired bulb(i dunno if a canbus resistor is needed cos i use white (blue coated) bulb)
5: reverse the steps and fix but the mirror housing.
If any bros need more help with this diy mod can pm me. Hope this helps.
  • Replies 6
wow great idea!
where can buy the sticker?
i went to a signage shop and "secretly" cut a few pieces of a variety of translucent blue, followed by some trial and errors, manage to make the yellow lights turn white.
