Squeaky driver seat
Guest ultor
Guest sy69u
had the same problem with my previous car. is ur car still under warranty? if it is, bring it back to c&c or to whichever workshop tat gives u the warranty when u bought ur car. maybe also u can try to put oil on the joints below the seat. if all that fails, bring it down to mbm.
Guest phicho
see if it is due to the seat belt catch rubbing against the leather. sometime it happens
Guest jenvid
It is either my weight or the leather rubbing against the plastic, how do I get rid of the squeaky noise if it is the latter? :bootyshake:
if urs is a W203, go to mbworld.org. There is a std list of squeaks & workard...
Guest ultor
bought a can of lub that comes with thin extended tube and sprayed around areas where the plastic rub against the leather, and also near the seat belt catch, problem solved. but the car can smell a bit for a day.
