rmjunior
Jerk when slowing down
29 posts in this topic
Lately, I have experienced a jerk when my car is slowing down at trafiic light or carpark entrance/exit. It does not happen everytime I slow down, but i would say it happens once or twice per week.
What could be a possible cause? Gearbox problem? My ride is C180K, mileage is about 20K.
Share this post
Link to post
go back to c&c for free diagnosis if still under warranty?
you could try flushing the ATF fluid and see if it makes it any better. shouldn't cost too much.
Share this post
Link to post
I used to have this occasional jerks at slow speed around carparks too. It's the gear change fom 2nd to 1st. But ever since I switched to RON 98 Caltex from RON 95, this disappeared. Are you using RON 95?
Share this post
Link to post
This 5 speed gearbox has this characteristic of jerking during the transition from 1st to 2nd when the speed does not match.
1 person likes this
Share this post
Link to post
yup. the jump from 1st (3.59) to 2nd (2.19) is quite big imho. if you go in C mode most of the time, you will feel the jerk less. 5G-TRONIC 3.59 2.19 1.41 1.00 0.83 3.16
2 people like this
Share this post
Link to post
But his problem is when slowing down...it's 2nd to 1st gear, not 1st to 2nd. I never had any jerk from 1st to 2nd.
Share this post
Link to post
I used 95 RON since day 1 but only recently experience the jerk.
Will try to switch to 98 and monitor the situation
Share this post
Link to post
yup... just mentioning the gap. but it is true, i only really feel the jerk from 2nd to 1st...
Share this post
Link to post
Mine also jerks when slowing down. Occasional nia so ok. C180k also.
Share this post
Link to post
i had the same problem. my first experience on the jerk was when i wanted to reverse and the car was rolling slowly to a stop when i felt a jerk. i initially tot i run over a small rock :) it happen once in a while especially when the car is rolling slowly to a stop. guess it tot it had stop and shifted to 1st gear abruptly
Share this post
Link to post
Looks like it's a Normal to jerk. I encounter it as well.
Share this post
Link to post
Precisely when you slow down to near stopping and the jerk comes when you apply accelerator. So the car goes from 5 to 4 to 3 to 2 to 1 (very slow now) and suddenly the jerk comes when it needs to quickly goes to 2nd.
I overcome this problem with my W203 by never allowing the car to slow to near stopping when I want to turn at a junction, knowing that I will accelerate to make the turn. You just have to play with the car till you know what is a good slow speed to avoid this jerk.
The 7gtronic has no such problem.
Share this post
Link to post
if a sprint booster works the way which i think it does, i don't think it will help this "jerking".
a sprint booster basically boosts/amplifies the throttle signal which is going to the ECU when you step on the accelator, if you give the car 5% throttle, it will fool the ECU in thinking you've actually depressed 10%, 15% when you've only actually stepped on 10%, and so on and so forth.
so if you're coming to a stop at 0% throttle, the sprint booster will essentially be in idle mode and register 0% at the ECU as well.
please correct me if i'm wrong.
Share this post
Link to post
What about when you guys change gear frm Reverse to 1st gear or 1st gear to Reverse? My my will jerk during the change and it felt like the gear engagement....
Share this post
Link to post
didnt encoutered this on a merc but on a e60 instead. could be down to the couple of reasons..
1. gearbox's (jumper or switch etc) giving way. there's actually a device regulating the downshift and such, did u meddle wif anything that will have an effect on the gearbox? (paddle-shift, non-compatible piggyback/sprintbooster etc)
2. transmission fluids and oils time for replacement/flushing? do a proper flushing and replacement of all related oils might help solve or reduce the problem from happening.
3. ecu miss-reading. same as no. 1.
hope this helps.. :)
Share this post
Link to post
no. not really jerk but can feel the change as in most cars.
Share this post
Link to post
i experience this in my C200 CGI. so it sounds common. ( : i am not worried though.
i am using RON92. huat ah!
Share this post
Link to post
I have this groaning sound when I switch from reverse to 1st gear.
But when I brought the car to Pandan to get it checked out, it stopped groaning!
Resume making noise again when I reached home.
Share this post
Link to post
i also have this problem of jerking when downshifting from gear 2 to gear 1.
it is quite prominent.... almost like someone bump you from the back.
I am going to try changing the transmittion fluid then monitor.
However, later i will reset my ecu first and monitor.
Share this post
Link to post
When slowing down especially when the car almost coming to a halt, my car's RPM will drop drastically and the car will jerk like going to stall... but this happen like a 1 - 2 second only... then it goes back to normal.
Looks like common problem huh?
Share this post
Link to post
Have this issue too sometimes. Not often though but comes and goes. For the past 2 years, probably 4-5 times.
Share this post
Link to post
Changing of gear with the 5 gears system on the C180K FL is really quite bad be it moving forward or reverse....mine is only 2 months' old.
Any remedy? May be C&C can upgrade to 7G-tronics FOC :-P Haiz, wait long long
Share this post
Link to post
mine 2 weeks already can feel it. i bring my c180 back to CnC next week. my steer wheel keep having a rubbing sound when it turns in low speed. i shall sound off the jerking issue to them see what they say....
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
