Planning to get a E250 Convertible
Speedmaster1979
Hi all,
I am new here and looking at this model comparing against the coupe, i am leaning towards the convertible more...
Would like to use this chance to get to know more people here and also have more knowledge of this model before getting 1.
Just a check if the soft top is really hard to maintain as the below 2 common issues here in Singapore & how do u guys maintain & counter with any form of protections?
1) Vandalism
2) Bird droppings
Last but not least, wishing all a prosperous Lunar New Year & huat huat all the way!!!
  • 1 year later...
  • Replies 4
  • 7 months later...
On 2/11/2021 at 8:44 PM, Speedmaster1979 said:
Its been a year since....
We have a separate chat for this forum in telegram. You can join for more interaction. Whereas for soft top. Normal maintenance and nowadays it is not too costly to replace. But I believe every few years will have to change. Common faults I see from other countries are the motor failure but the material used seems to be quite sturdy.
  • 1 year later...
On 1/24/2020 at 4:41 PM, Speedmaster1979 said:
Hi all,
1) Vandalism
2) Bird droppings
One words of advice for ppl contemplating a Drop the top,TopLess Driving is……..
There’s some Golden Rules.
U can’t have sumthing for Nuthing .
The Opening Mechanism needs to be serviced ,if u Buy preown ,u gotta send the Cabriolet either a soft or hard top for a once over,immediately.
The whole operation is controlled by 2 Cylinders ,after a period of time ,the hydraulic oil can go Depleted cos the Rubber seal harden or crack .
once the oil goes below certain Level ,the opening & Closing will be effected.worse case scenario is once u open ,u Cannot Close.
Worse embarassing ever & if it rains ………
I noe of many Cab owners NVR opens their Roof.
Dat defeats the whole purpose of owning one,realli.
For New one’s ,u still gotta go wshop at Least once a year,for a check & spray some Coating over the Fabric for waterproof purposes.
  • 5 months later...
