Wj1984
W205 C180 passenger side aircon not cold
Would like to check any bro here experience the passenger side air vent and the left air vent on the centre console are blowing out air which is not cold?
the rest of the air con vent is ok all have cold air
can advise what the issue and what to repair/replace?
am driving a 2015 c180.
Share this post
Link to post
Did you check if the sync button is pressed to control the overall temperature?
cos each side can set different temperatures
Share this post
Link to post
not enough Air Con Gas, the condenser is place horizontally which means the gas travels starting from the driver's side to the passenger vents
Could be leak but just top up one time to monitor
Should change the air cabin filter if it is dirty otherwise condenser easy to Ki Chia
Share this post
Link to post
