Yeoth19
W204 C250 coupe customize forged wheel
Hi Bros,
What is the best offset for 19" wheel if i going for customize?
The shop fellow say go for 235 all rounded. Front 19" 8J  x 28 offset, rear 19" 8J x 35 offset to have abit of concave look.
Somehow don't sound right to me but im not too sure too.
Share this post
Link to post
"Front 19" 8J  x 28 offset, rear 19" 8J x 35 offset" if you fit the other way round makes more sense. ie front more offset, back less offset.
My experience is 8J offset 35 mm (flush with front fender, plus minus) or more.
235 on 8J may make the tire look a bit like "donut".
IMOP, just thinking aloud.
cheers
lz
Share this post
Link to post
hi buddy i suggest for front i reckon 8.5 JJ not less that 42mm, for 9.5 jj not less than 54 mm.
But i reckon a sport rim shop can give you better advise. You should "put on" the wheel to see if the offset is ok. Rims with and without tires can make slight difference on the "flushless" with the fender due to tire design. ie some rims has rim protector like the PZ4 and can make the more "out" then it really it.
hope this can help you.
cheers.
Share this post
Link to post
