amg bbk
  • Replies 10
I'm a bit confused here. Are you trying to fit the C63 AMG BBK into a W212 with AMG 18" wheels or are you trying to fit the W212 AMG wheels into a W204 with AMG BBK? Either way, it won't work.
What I meant was to fit the c63 amg bbk into a w212 with 18" AMG wheels.
Becos when I enquire from one of the seller in mbworld, he told me it can be fitted without mod. Just wana verified. Sorry for the confusion bro. :)
As far as i done my research back then .. all gen 18" AMG rim "should" fit the AMG BBK with 365 mm rotor ... the clearence for the radial portion of the caliper will be minimum but there is some amount of clearence (2 to 3 mm) ... usual comment is go for 19" if you wanna have a AMG bbk to have better clearence.
for face of caliper clearence with the rim, i don't see a problem cos it will surely be better than that of the radial portion(caliper) clearence
hope this makes some sense to you and help u in some way ...
cheers
lz
