good paint job?
currently blk will it cause damage to car if I change white colour? heard from car workshop they need to remove everything out to spray paint.. worry that the rubber will loosen... anyone had ur c class colour changed?
the problem is especially at the windscreen, the painter needs to remove and after painting put silicone ard the front n rear windscreen......, soundproof not so good then after that.....ard the doors, all the rubber seals and panels will be removed....
had been wanting to change colour too.....having heard about the inconvenience and all sorts of .."risk:", i had not done anything.....:)
