Some questions regarding the DRL
Guest kai
Hi friends,
I understand that the DRL will turn on automatically for the E-class Avantgarde Model when you switch on the engine whereas for the E-class Elegance Model, it won't happen even when you change the fog light to the DRL. Is it possible to modify the Elegance E-class so that the DRL will turn on automatically when you switch on the engine? :music:
Guest vincemerz
kai wrote:
Hi friends,
That function is called welcome home light. I guess it's in the setting. Should be can. Cause last time my c class also like that. Unless wiring went wrong when you change the drl.
