WTB: Stock W212/C350 (E250/E350) Stock Twin exhaust or Trapezoid Exhaust
Guest E-CAB
  • Replies 3
Guest busdriver
Quite a lot of cutting to get it installed.... Right side will be empty (see thru) after installation unless u purchase the E350 exos box to fit. U will also have to cut the plastic cover on the lower left to get the tip fitted and purchase the rear valance as well. Left side exos will not be aligned with the trapezoid outlet resulting in the rear valance melting. To solve this, u need to customize and weld the outlet into the trapezoid tip.
Tks for the tip. Better to get another diffuser rather than cut. But may afraid it may look too fake. :becky:
There r a couple of "tuners" exhausts available.
But at $4k w/o much difference in ponies, doesn't justify the spending. :Cry:
Will look around...
Guest busdriver
Will look around...
If u do it right, it will be worth modifying your existing stock exos. PM u dtls...
